Fnac : 2 jeux de société achetés = le 3ème offert (le moins cher)
nouveau crate engine 525 hp ls3
nouveau crate engine  525 hp  ls3 Empty nouveau crate engine 525 hp ls3
Message par firebuick 24/3/2013, 17:07
regarder spec de se moteur la 525 hp avec 376 po cu
•Displacement: 376ci, 6.2L
•Bore x Stroke: 4.060 x 3.620-inch
•Compression Ratio: 10.7:1
•Recommended Fuel: 92 Octane
•Block: Aluminum with 6-bolt cross bolted main caps.
•Crankshaft: Nodular Iron
•Connecting Rods: Powdered Metal Steel
•Pistons: Hypereutectic Aluminum
•Camshaft: Steel Hydraulic Roller Tappet
•Cam Lift: 0.525-/0.525-inch intake/exhaust
•Cam Duration at 0.050-inch: 226/236-degree intake/exhaust
•Lobe Separation: 110 Degree
•Cylinder Heads: Aluminum LS3 style rectangular ports.
•Combustion Chamber: 68cc
•Valves: 2.165/1.590inch intake/exhaust
•Rocker Arms: Cast roller trunnion, 1.7:1 ratio
•Balance: Internal
•Reluctor: 58X
•Maximum GM Recommended rpm: 6,700
http://www.chevyhardcore.com/news/spotlight-chevrolet-performance-525hp-ls3-based-376ci-crate-engine/
nouveau crate engine  525 hp  ls3 Empty Re: nouveau crate engine 525 hp ls3
Message par yves5458 24/3/2013, 17:12
que veut dire Reluctor: 58X
nouveau crate engine  525 hp  ls3 Corvet17
Message par firebuick 24/3/2013, 17:47
yves5458 a écrit:que veut dire Reluctor: 58X
je pense ces dans distributeur pour le timing nouveau crate engine  525 hp  ls3 846390 t bo
